주요 콘텐츠로 건너뛰기
The TI-36X Pro is a scientific calculator manufactured in 2011 by Texas Instruments, Inc. It features a solar cell and backup battery for more memory storage.
Why don't the buttons on my calculator work?
When I press the buttons on my TI-36X, nothing appears on the display.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개:
Kevin Rangel, does your calculator turn on at all?
I hqve this problem also.
it remain on and no button are working .after sometimes it is off.i tried several times but the problem remains same.please guide me to solve thus issue
댓글 달기
답변 5개
Check if any buttons are stuck beneath the casing. This may prevent your calculator from responding when you press a button. If no buttons are stuck, reset the calculator by pressing the reset button on the back of the calculator with a pen. If none of these steps work, go to our TI-36X Pro Troubleshooting Guide
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
not helpful... none of these work
where is the reset button
댓글 달기
Yes, thank you so much! Resetting my calculator corrected the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
where is the reset button?
댓글 달기
Everything about my calculator works perfectly except there are no numbers on the keypad. I have to try to remember where the numbers are at when I am typing because there is nothing there. What is wrong with my calculator?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My calculator can’t on..can you tell me the factor why it can’t on?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
so my calculator won’t work and it just shows on the very top corner error and the number I type in barley shows
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kevin Rangel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 14,521
