주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
Why is my Galaxy S3 stuck on the samsung logo?
So I put my galaxy s3 on factory restart because it kept freezing on me and now I can't get back on. Why? I don't know. It loads and then it gets stuck on the blue samsung logo, then shuts off and no matter how many times I try, it doesn't load. Please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 6개
가장 유용한 답변
When you do factory reset may damage some files and cause the software problem. You can try to root the phone.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
i am having the same problem
댓글 달기
Boot into recovery and wipe data or factory reset
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Sounds like you reset the phone from the settings menu, correct? Try this:
Hold Volume UP, and the home key down at the same time. Now, while still holding those two keys, press and hold the power key.
When you see the Samsung logo you can let go of the power and continue to hold the other two keys. You will see a screen with blue text that says "Android Recovery" at the top.
Now use the volume down key to scroll down to "Wipe Data" and then use the power key to select it. On the next screen scroll down to Yes then again select it with the power key. This will hard reset your phone.
When it boots up, allow upto 15 minutes for it to fully boot.
Report back with what happens!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you! Just had this problem after doing a factory reset on my old S3 phone and your instructions got it up and running again.
댓글 달기
If you can't boot into recovery and only download mode and can't recover via Odin your eMMC chip is dead known as sudden death syndrome with the S3, or it just naturally died. Your options here are removing the eMMC chip and using a micro SD as bootable storage (last resort)
try recover via odin etc first
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I tried to use your solution, but when I downloaded the odin 3.07 I got a browser hijack spamware and just got done getting rid of it. Now I downloaded Avast to get rid of it it wont let me download it at all due to malware stuff in it. http://spacyroot.com/
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You might have to reset the p-ram . In iPhones,this is achieved by disconnecting the battery and then reconnecting it. Hope this helps you out with this problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DJ Kitty 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 37
전체 시간: 7,504
