주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 질문 전체 보기
Squeaking noise when start up on Maytag Bravos Quiet Series 300 dryer?
The dryer is squeaking when beginning a cycle
After it is warmed up or in use for a few minutes it seems to not be as bad
Is there an easy troubleshooting method?
Could it be a bearing or is it a belt?
Where do I begin?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 2개
가장 유용한 답변
I find your photos of a repair on a GE dryer interesting, but this is not the same design as the Maytag (Whirlpool) dryers. The Bravos 300 series are very similar to the Maytag Neptune series.
To replace the two wheels (located inside the rear of the dryer) on which the dryer drum rides - these do wear out depending upon frequency of machine use and size/weight of the loads. The front of the Maytag machine must be removed, then slide the drum out, and use a ratchet with socket to remove the two wheels with their holding bolt. A kit containing all the necessary parts can generally be purchased through an appliance parts center for about $40-50. Be sure to have your model number when ordering/purchasing the parts.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It's probably a worn out drum bearing. Here's a pictorial guide on replacing one: http://marksprojects.wordpress.com/2009/...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
rick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 16,978
