주요 콘텐츠로 건너뛰기
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 질문 전체 보기
I stripped my screws on the motherboard, what can I do?
In an attempt to replace a cracked screen I accidentally stripped the small screws on the motherboard. Any suggestions on how I can get past this? I cannot get to the screen without removing these screws. I tried the rubber band and duct tape tips unsuccessfully. Please help anyone!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Happened upon this. Reminds me of a macbook pro keyboard replacement a while back, one screw stripped, and of course there are (around) 67 screws that hold in that keyboard. One in 67, yeah, it happens to everyone from time to time. <cringe>
For completely rounded out, stripped, small screws in iPhones, iPads, iPods it is possible to firmly press the blade of an xacto into the screw at around a 2 degree angle. With enough pressure the exacto will cut into the side of the screw hole and the point will grasp the opposite inside which should give you just enough leverage to slowly back the screw out. If you use this method, use patience as you start to feel the blade "grip" the screw. And when I mean patience, it has taken me up to 5-10 minutes to slowly work out a 1.6mm screw.
I commonly use this method in my shop when a first-time 'do it yourself'r' brings in an iphone that they intended on replacing the screen (after watching that cool youtube video), and right off the bat strip the pentalobe screw with a philips head. 8-
This is always a last resort, but, over the years I've found it effective.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Follow the tags at right for some possible tricks to try with stripped screws.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Pu tin slightly larger self tapping screws.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vivian Miracle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,518
