주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
cant use cellular data,says no service or keep searching for signal!
hi,
when i turned on 3g its completely normal for a few seconds(sometimes few minutes though). i can only make calls and send messages when cellular data is turned off!!!i tried almost everything on here and Google.can anyone help me here? :( :( :'(
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
sorry,couldn't mention above.i have an iphone4 GSM!
sometimes it shows "RESTORE NEEDED iPhone cannot make or receive calls,please restore!"
댓글 달기
답변 3개
가장 유용한 답변
Hey Lan,
Considering it states "Restore Needed" have you attempetd resetting the phone to factory settings through Itunes? That way you can find out if it's a software or hardware problem.
Also, when did this start happening? Was it after a drop? After spilling water on it? Or does it seem completely random?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
My daughter has my old iPhone 4 and it started doing this. I restored. It did the same thing after a few minutes..... I restored again, and again.....No difference. So I searched the internet and tried everything possible. (New SIM, turning off the PIN code, turning off 3G, Restoring in various modes.....etc, etc)
I was about to throw it against the wall................
"Wait.....", I thought to myself..... Sometimes it doesn't register that I take the SIM out, and sometimes it didn't register when I put it in, or it took longer than normal to notice.
"Maybe the contacts are corroded or covered in dust?". I sprayed WD40 onto to SIM and inserted it. Voila!
2 days and it hasn't lost signal. Hasn't asked me to restore. Runs perfectly, again.
I can only think that the contacts were dirty. No idea how because it's in a case, and the SIM hasn't been out...... Almost 2 weeks of stress and head scratching for a quick squirt of WD40.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have same problem my Iphone 4 GSM lost signal and no service appeared specially when I use cellular data for internet browsing, so I will try ur way and clean the SIM card place, hope it will work....
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hey guys finally its worked ty martin just cleaning..
tyvm
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,226
