주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
no sound while recording video
If I'm correct the upper mic is the one that records the sound for videos and the speaker during calls.
This mic is not working. What can I do to fix this?
The mic works perfectly during calls (no speaker), while recording audio on whatsapp, and recording voice memos. So I know the problem is the upper microphone and not the lower microphone.
How do I fix it?
Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 7개
가장 유용한 답변
I have had this issue three or four times, usually after I installed an app like voice recording, or recently, streaming radio. So far, rebooting has almost always fixed it. Once, I did have to delete the offending app.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Here also: no sound on recorded video. Turn iPhone 4 off/on fixed it.
댓글 달기
The iPhone 4 has this as a common issue and most of the time it can be fixed with a simple hard reset.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The Proximity Flex cable for the GSM iPhone 4 contains the top mic, so if that is your problem changing that flex cable should solve the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
What joseA said the upper mic is located on the proximity sensor replacing this will sort you out
이 답변이 도움이 되었나요?
점수 0
댓글 달기
https://www.youtube.com/watch?v=Fvtxp8Va...
Check out this video 100% solution easy without tearing apart your iphone !!!
Like if it worked.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I used to use my iPhone 5s to record a show. Even though the show was extremely loud, my phone still couldn't record any sound. I searched the internet and found one answer: tear off the plastic cover on the back of the phone. I found there was a tiny hole besides the camera, which I assume it's where the audio inputs. I did record sound ever since I tore it off.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hi,100000% change the dock connector,just done 2 iphone 4
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mel Dominguez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 20,429
