주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A470은 2008년 1월에 발표된 710만 화소 디지털 포인트 앤 슈트 카메라입니다.
many line images why
The taken image have many line above the image. Can any body help me
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
it would be a good idea to upload a image with that problem.
의 공유
댓글 달기
답변 2개
선택된 해법
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, Please see this link for further info and a simple fix that may help.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Go to Canons site
They have support pages - the CCD might be under extended warranty.
I had a problem with an A75 taking blurry images and they fixed it for the cost of shipping.
Good Luck
N.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sandeep Hijam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 58
전체 시간: 11,964
