주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
Lock/Power Button STILL not working?
Hi. I recently replaced the audio and lock button cable and all of the buttons seem to work fine except for the power button itself? It is clicking more accurately compared to before. I didnt replace the lock button itself only the cable it works off. I dont understand the point in replacing the lock button itself because it is just metal and has no moving parts etc? so if i am in wrong about the button could someone please help me? i dont want to pay for a button if there is no need for it. P.S. if the button does affect it then why is it my lock button still wont work? Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If you are hearing it click then it's a faulty flex as the volume buttons work
You can just plug in the power flex next time with out installing and see does it work this will save you taking the phone apart
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Okay then! Thanks very much for clearing that up:)! Will buy a more trusty cable. Thanks a lot!
댓글 달기
Does the volume buttons work?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
They both do yes
No problem had this issue myself before but it's the volume buttons that didn't work a new cable sorted it out
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 145
