주요 콘텐츠로 건너뛰기
Apple의 올인원 데스크탑 컴퓨터. 2006년부터 2011년까지 인텔 프로세서가 탑재된 iMac.
7454 질문 전체 보기
iMac 27" buzzing and will not power on now?
my iMac 27" was making a buzzing noise in top left corner (if looking at it from front) when on and I tried both resets nothing worked. It was asleep and after a storm will not power on at all now. I tried unplugging for a few minutes and plugging back in, waited over 24hrs and still nothing. Any ideas? Power supply?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
ok so i unplugged the power cord from back and waited 24hrs. Plugged it back in and it powered up but still has loud buzzing coming from the top left corner. Power supply causing the buzzing?
What are the last four figures of your serial number ( located on the bottom of your stand)? This tells us which machine you have.
Last four are DHJV Thanks
댓글 달기
답변 1개
선택된 답변
The power supply is indeed located in the top left corner and over the years power supplies have often exhibited buzzing sounds when they are failing. The LED driver board is also in that area though it doesn't have nearly as much power flowing through it so buzzing would be kind of odd. With what you've given us I'd say the power supply is probably a safe bet.
With that said, if it fails again I would check the diagnostic LEDs to see where the power flow is failing. Most of the 27" iMacs (before they lost the optical drive) have 4 diagnostic LEDs just to the left of the RAM slots, visible through the grill at the bottom of the Mac.
LED 1 indicates trickle power is present, this should always be lit if the Mac is connected to a power source.
LED 2 indicates that the logic board has received power from the power supply. This is the one I'd expect to see be either noticeably dimmer or dark compared to the first one if the power supply is flaky.
LED 3 indicates the video card is functioning.
LED 4 indicates that the display is functioning.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Ok I will check those out and let you know. Thanks
댓글 달기
귀하의 답변을 추가하세요
Brandon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 2,732
