My samsing galaxy note 3 is grounded. how can I fix it?
My phone started to be grounded. when I charge it it starts with 68% or 100% then when I remove the charger it becomes 0%.
좋은 질문 입니까?
좋은 질문 입니까?
Hello Baham,
I am sorry to hear you are having troubles with your phone, the problem isn't your phone however it is your battery. The Note 3 drains the battery so quick that it ends up killing the overall life of the battery!
I would check eBay for an OEM part, don't go for the $4.99 one it should be around $25. This will ensure that the battery will last more then a week!
Hope this helps, Good luck!
해당 답변은 도움이 되었습니까?
My samsing j5 2015 is grounded, if i didn't plug the charger the auto touch will appear if i plug it the auto touch is gone, how can i fix this, isn't replacement of lcd or something that is part of the phone,?
해당 답변은 도움이 되었습니까?
just reground you cell everything gotta be fine
it will cost around 100 INR
for more info ( owaizkhan228@gmail.com )
해당 답변은 도움이 되었습니까?
Samsung note 4 grounding and battery is draining to fast what app can be down loaded to repair this problem
해당 답변은 도움이 되었습니까?
my samsung galaxy note 5 is grounded too!
해당 답변은 도움이 되었습니까?
my samsung galaxy note 5 is grounded too!how can i solved this! or where can i find a technician? for this solved my PHONE :(!
24 시간 전: 10
7일 전: 22
30일 전: 30
전체 시간: 7,927
