주요 콘텐츠로 건너뛰기
The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
23 질문 전체 보기
HELP!my phone completely broken won't power off &alarmclock wont stop
My phone got smashed so I have a cracked screen and all the buttons are messed up. I try the power button it won't shut off i try power button and + or - volume key and that won't work...so my phone is stuck on and to make it worse my alarm clock keeps going off and I can't make it stop going off cause the buttons don't work and my screen is completely black.if it wasn't for the alarmclock and led lights blinking you wouldn't even realize its on..I'm about to go crazy please help I just need to power this dang thing off
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Lindsay, start off by removing the battery. Use the first minute of this video to get it accomplished. After that you may have to disassemble your phone totally to evaluate the damage, Repair/replace the parts as necessary starting with the display assembly. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You can try rebooting your system just hold the power button for 120 seconds and it should cut back on and you should still have your stuff back
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Not difficult people, remove the battery!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lindsay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 2,180
