주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
What is the F26 code?
Washer turns on and starts to add water and then clicks off. The timer works and eventually the F26 starts flashing.
Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
what is the f 06 code stand for?rlonadier@windstream.net
I have a load in the machine and get start there error code F26. How can fix the problem
댓글 달기
답변 1개
It is a door switch error code, either the connecting wires are loose or the switch is defective. The door switch error code will also be seen if the door is not closed completely. Look fro loose wires first.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The wires were fine so we are going to replace the door switch. Thanks so very much!
댓글 달기
답변을 추가하세요
Cindy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 5,353
