주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20003 질문 전체 보기
질문 마감됨
Repartitioning fails in Internet recovery: is the HD salvageable?
Internal HD failure in Early 2011 unibody. Had recent-enough backups (of individual important files, not Time-Machine-formatted), so decided to just reinstall from Internet Recovery. The HD showed in Disk Utility, but showed as a single unformatted partition. Okay, reformat the drive. This gave the "Unable to write to last block" error
On a few subsequent tries, it seems that the internal hard drive will show (unformatted) if I enter Disk Utility immediately, but will not show if I quit and re-enter Disk Utility (without a backup), nor will it show in the Reinstall utility. DU shows no problems recognizing the external HD or optical drive, so it's unique to that drive.
So: is the drive totally borked? I can try to set up the external to boot from, but I imagine it would throw a similar error. I opened up the case and checked that the HD cable and bracket weren't loose or dusty, but I didn't look for anything more specific than that.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Put the drive in an external enclosure or use a Universal adapter. This will bypass the suspect hard drive/IR cable that are notorious for failure.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 146
