주요 콘텐츠로 건너뛰기
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 질문 전체 보기
My iPod does not detect scroll wheel or button.
About a year ago, the device was left on a table and sometime in the night, water was spilled and the nano was left overnight surrounded by it, but only a thin layer. After that, the iPod stopped turning on. A few minutes ago, I tried to see if it would work, so I plugged it in and it turns on, but the scroll wheel will not function, nor the middle button.
Also, this is probably something else but, the nano seems to shutdown after being unplugged.
I would be happy to know if it can still be salvaged or not.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
since the water spill was so long ago and the iPod has had plenty of time to dry out, I would guess that there's been some internal damage or corrosion. I think the next step would be to try opening up the iPod and see if there's any visible damage - you may need to replace the click wheel.
shutting down after unplugging is probably just a sign of a dead battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The nice thing about the Nanos is that they are are very small. The less nice thing about them is that many of their parts are integrated into the logic board.
Having that said, try replacing the click wheel. If this doesn't solve your problem, all signs point to the logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
put your ipod on some warmer place like the radiator(around 50 to 60 degree C). The click wheel of my Ipod did not work after it touched with a little bit of water, I fixed it like that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 3,451
