주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
iPhone 4S is not working
A friend of mine recently dropped his phone on a marble floor. The phone was encased in a rubberized case. It bounced a few times and now is not working. Anyone have any idea what might be broken or disconnected? It will not boot up, it does vibrate, I cannot get it to soft or hard reset. There is nothing showing up on the screen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi,
The only thing that you can do is to try connection with the computer at DFU mode. If there is not reaction from the computer for connected device, you have a hardware problem. The phone should be opened and examined from a specialist.
Regards.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Do as ZFix says, connect iPhone to iTunes on computer, if iTunes identifies the iPhone correctly, then the screen is disconnected or damaged. Then check to be certain the LCD Display connector is perfectly connected to the logic board, if after connecting the LCD Display perfectly there is still problem you need to replace entire front screen assembly.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
lsoldano 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 148
