주요 콘텐츠로 건너뛰기
2013년 6월에 출시된 Galaxy Mega는 720P 스크린, dual-core 프로세서 및 8MP 카메라를 장착한 6.3인치 스마트폰입니다.
Why isn't my Samsung Galaxy Mega's touch screen working?
My floors are concrete. My phone (Samsung galaxy mega)slipped off of my counter and landed face first, completely shattering the top right side of the screen. It turns on and off and the screen is normal looking, but the touch doesn't work anymore. I can't unlock it or anything. Can I get it fixed or is it just cheaper and easier to replace it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 20
댓글 1개
hello help me to boot my samsung galaxy mega
댓글 달기
답변 10개
가장 유용한 답변
Hi Michael,
It seems as though the digitizer in your phone is faulty (as you probably know) and needs to be replaced.
Here is one source for replacement parts for your phone. (Select the part suitable for your particular model number). It is not a recommendation to buy from the seller it is only to show what is available and what the cost is.
http://www.etradesupply.com/catalogsearc...
Here is a link which shows how to replace the digitizer in your phone. It is in German but the video is self explanatory. It may be easier, (and less stressful and perhaps in the end cheaper), if you are going to do it yourself and do not have all the required tools necessary, to replace both the LCD screen and the digitizer. Then you do not have to separate them, just to replace the digitizer.
https://www.youtube.com/watch?v=edURB0NN...
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
i think you'd replace it my phine is the same way and its acting up im gonna replace i suggest you do to.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My Samsung Galaxy mega 2 doesn’t slide
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Check with local shops, you need a new Digitizer. The part is a lil pricey as it consists of the LCD, Digitizer and Glass. You will probably spend anywhere from 150-200 at a shop to get it fixed.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I have the the same problem, is the LCD, DIGITIZER and glass the same thing
They are all different parts to the screen.
LCD is what lights up to make the picture
Digitizer is thin sheet of glass with some circuitry around it that handles the touch screen functionality.
The Glass is literally just an additional plan of glass the protects the other 2 parts on the outside. This is the part that usually breaks first. Some glass can be removed and replaced without the need of replacing all 3. While the Samsung models "can" replace the glass only it is a tricky process as the glass is glued to the digitizer and separating them can cause damage to your touchscreen.
I sat on my samsung mega and cracked the screen. The screen still works, an the menu bottom, an the back an home button still works. The top half is responding to touch but not the bottom half. What to do to fix it?
댓글 달기
Remove the the back cover and bezel. Then you'll see the motherboard there and you want to remove that as well. Don't worry about removing the bottom charging port or any other components. Underneath where the motherboard was you will see the digitizer flex connection (not the lcd flex cable). You may try sliding it out of the connector and placing it back in. Assemble everything back together and your samsung galaxy should work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hello are you there please my samsung galaxy mega
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My galaxy meg 6.3 will not download apps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
will my phone has been dropped and now the okay botten and the zero and the energy calling its not working the rest of the numbers are still working but not those three things.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My son smashed my samsung galaxy mega and broke the glass screen. I had the glass screen only replaced. It works better now. Even tough the touchscreen is not as responsive as before but i can still use my phone which is great. So yes, you can replace the glass screen only.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello please how do I go about my phone . Its always on the home key does not work. Its always illuminating it self and its so frustrating. I ve flashed it I ve changed the touch pd yet its still fluctuating. Please help. Where I can reapir or how to repair .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricky 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 45
전체 시간: 21,326
