주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
질문 마감됨
iPhone3g problem with itunes recognition
have problem with iphone 3g
Slow charge over usb and fast battery drain
itunes wont recognizes device anymore when plug
But everything on phone work good
last software 4.2.1 installed
Any sollution
Thnx
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
does the dock connector function properly? has the phone been jailbroken.. often with the 3g and 3gs if they have been jailbroke itunes doesnt accept it untill the jailbreak has been removed. if the phone charges you know everything is okay on the inside.. have you tried to plug it into another computer?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i tryed another computers and its same
yes phone is jailbroken but and 6.1500 baseband for unlock operator
and did work properly before
didnt check dock connector yet possible there is a problem?
thnx
댓글 달기
가장 유용한 답변
If a known good charger and cable are used, and the issue remains, there could be a few steps you can try, in addition to the above by Curtis, such as:
- You can try to rule out the software as possible reason for the iTunes detection issue by removing the jailbreak (unless you can't give it up).
- Slow charging and quick discharging could be due to the battery dying on you. I would disassemble the phone to take a look at the battery battery using the iFixit guides. A good sign of it going bad would be that it's swollen. But it could be retaining it's flat form and still be bad. You can replace it to make sure.
- You can then try replacing the dock connector, also as mentioned above by Curtis.
- Finally the issue could be due to a set of components on the board that prevent the phone from being detected and/or from charging correctly. This set of components will need a well trained technician to trouble shoot and replace them if needed.
If you try any/all the above and report back with your findings, we may be able to help you more.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 89
