주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
after repairing the power button the screen stays black
Hey, I just fixed the power button issue (I replaced it by new one) but now I have a bigger problem: When I tried to switch the iPhone on the screen is staying black. The power button works and the iPhone turns indeed on but I can't see anything. Do you have any idea what I might did wrong when I disambled my phone?
With kind regards
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Either the connections are not seeded or the screen has gotten damaged during disassembly.. Did you take the screen out when changing the power button?
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
thanks for your answer! no I did not touch the screen at all. I "just" removed the logic board and put it back ;)
A new display is what you need mate
Excuse me? I need a new display, since I might bond the screen flex cable?
댓글 달기
That's your problem then you need to remove the screen to get at the screws of the power button bracket not fold the lcd flex cables this is were you have damaged the cables..
The lcd cables should never be folded forward like that ;)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
ok !@#$ it :-/
soo... What's next?
댓글 달기
이미지 내용 보기:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 125
