주요 콘텐츠로 건너뛰기
질문 마감됨
upgrading to leopard from Tiger
Hi, can i upgrade to leapard and if so, what version should i buy?
Many thanks
Peter
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Here is a link to Leopards requirements. Pay close attention to the CPU speed and memory needs. Assuming you do have a iBook you have a PPC processor and would want Leopard 10.5--your computer will not run 10.6 Snow Leopard. And please be sure you get a retail copy or it may not work. There are a lot of machine specific versions out there. Good luck. Ralph
http://support.apple.com/kb/HT3759
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
댓글 달기
가장 유용한 답변
Even if it has the 867 MHz or better processor required, and you've maxed the RAM out, and you have a DVD to install it, you may find your performance loss unacceptable, and be disappointed. I'd really stick to a maximum of 10.4 on this machine.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
댓글 달기
Even though you can support leopard, and you can meet the specs by upgrading, I strongly suggest you do not upgrade, as it will not preform well on you machine, making it laggy and in general having low performance. My policy is generally X-1 for optimum performance on older machines, where X is the maximum OS.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,166
