주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
질문 마감됨
Boot loop after screen replacement
I have repaired many iphone 4 screens and have not come across this problem. I changed the screen assembly and got the phone back together and working. It seemed fine when I handed it off to the customer. Wifi was good, cellular had signal, digitizer was operating fine. I had no indication of a problem until the next day. The customer brought the phone back and said that it just shut off and only would come on if plugged in. I took a look to find that when plugged in it would boot to the ios6 greeting screen as if it had been reset but it would not move past that screen. Cellular signal was stuck at searching (witch I realize is irrelevant at this point). I disassembled and checked connections and for visible damage and found nothing. I did notice a burnt smell inside the phone but no other evidence of burning (heat,smoke, black areas on board or housing). now that I got it back together it only boots to apple and cuts off before it completes boot process then comes back on. any advise is much appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
100% a damaged battery a new 1 will fix it ..
Had this problem before
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Battery, charging port flex and the cellular antenna/speaker in closure have been changed with known good parts and no dice. It's down to a mobo problem. Does anyone know what chips to check for power management? We're is the pmu ic?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
However, you can try to fix this with recovery mode which is a failsafe that is used to reflash your iPhone with a new OS.
A great tool i ever used to enter and exit recovery mode is ReiBoot developed by Tenorshare. Have a try. Safe freeware and won't lose data with this process.
Good luck!
Kirsty
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 600
