주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z는 2013년에 출시된 안드로이드 기반 스마트폰입니다. 5인치 풀 HD 디스플레이를 탑재한 Xperia 제품군 중 가장 큰 스마트폰 중 하나입니다. 모델 번호는 C6603/C6602 등이 있습니다.
GPS Issue, Gps module/antenna location?
Hi, my gps on my xperia Z don't fix anymore, (0 Sat fix every time) i think i have an Hardware Problem, can somebody tell me where is the GPS part (antenna if there any, or component) ?
Thank you in advance !
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 11개
가장 유용한 답변
I had the same problem and was just able to fix it.
By pushing the charger-jack to the direction of the display or pushing on the phone close to the same jack sometimes the GPS still got some fix. So it seemed that my GPS antenna was somehow disconnected.
The antenna seems to be a plate which is located in the inner frame of the phone (see here https://www.youtube.com/watch?v=zeBC3pcs... on1:24). I cleaned the contacts located in the frame as well as on the side of the maonboard and bent them a little bit towards the frame. I guess the most important one is the golden one right under the charger-jack (see 1:41 on the very right side).
Since then its working again ;)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Got the same problem since july on my Xperia ZL.
After some research I noticed that my compass is going nuts, it keeps rotating. So since the phone is not able to detect North, East, South and West, he isn't able to obtain a GPS lock.
You can check that by entering in your dialer : *#*#7378423#*#*
this wil open the Sony Service Menu, go to service test, and there test your compass.
I got the yaw value that keeps increasing to 359, and then restarts from 0, like in this video : https://www.youtube.com/watch?v=l7je_iec...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
ZL model, GPS just stopped working while using a GPS app november 2014. Hasn't worked since.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
got the same problem with my Z3 compact... after some weeks of good and accurate functioning, I can't get no fix anymore!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
same problem here :-( sony xperia t3
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi
Same problem a you.
No more gps fix after upgrading to Lollipop.
Sony xperia z3.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same problem here in Xperia Z3 compact... GPS Test shows No Fix, so it can't locked the satellites that there are about 20 available. Has anyone managed to solve this problem?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Having same problem with Z5... terrible finding fix and takes way too long, despite seeing more than 15 satellites at any given time. Anybody found a fix? I've attempted to work the issue with the Service Provider and there is nothing on their end that they can do. Constantly having to perform the GPS reset, power down and then the time consuming GPS location test, for the phone to forget location 30 mins later.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Solution?
I have the same problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Type in the code as described above to enter the Sony service menu. Go to:
service tests -> GPS
Then tap 'purge assistance data'. GPS apps contain tables to help them locate the sats by predicting where they are. If this is corrupt or incorrect it will knock out yr GPS. Purging refreshes the tables. Did it on mine and it clicked straight in! Also holding phone vertically appeared to help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Sameproblem with my xperia zl, after replacing the battery gps cant fix.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kevin THIERY 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 24
전체 시간: 26,662
