주요 콘텐츠로 건너뛰기
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127 질문 전체 보기
Why is my screen blank when I power it on?
When I turn on my notebook there is no screen. I can swipe my finger over the lock feature and it sounds like it goes to the desktop page. Any ideas what is wrong??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
It sounds like your LCD is broken however I would make sure that your screen is just not extremely dim due to either a brightness setting or a fried backlight.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Samsung has a known problem with this model!!!!! IT IS WELL AWARE OF FAULTY WIRING CAUSING THE SCREEN TO GO BLANK. THEY WILL EVEN GO SO FAR AS TO TRY AND VOID YOUR WARRANTY AND FALSIFY DOCUMENTS. I doubt that your lcd screen is broken. Do a google search on samsung note 10.1 black screens!!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Anyone ever come up with a solution to the black screen on the note 10.1 2012? I took off the back panal and undid the tape on the far right and it caused my screen to go completley black. Prior to that the screen had lines on it and the keyboard was off "track" . The screen would flicker and show the same graphic over and over...it wasnt dropped to my knowledge.
Just wondering if anyone has any suggestions. The tablet was purchased new in 2013 and only used about 5 times prior to this happening...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Breia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 1,770
