주요 콘텐츠로 건너뛰기
The third iteration of the 10.1 inch Galaxy Tab tablet.
126 질문 전체 보기
Colored lines/stripes on screen problem
Hey!
I bought this tablet about 6 month ago, and dropped it accidentally today (2 feet from the ground).
When I boot it up, I can barely see the samsung logo and the flashy animation, I can also see some of the apps/animations of swiping etc. So I guess the tablet still works. Perhaps a misconnection happened when I dropped it.
I watched some videos on how to remove the case, and I did not notice any misconnection :(
Help please?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
I dropped mine few inches and cracked screen. Paid £70 for tempered glass screen. After 3 months it is always bright colours on screen. It would not even work for 2 weeks. Bright yellow screen
Still rang but was no way I could answer it
It's just started to work again but thick black lines to start with and usually ends up pink or blue lines after a while. Do it take to phone shop. Will they be able to fix it without too much expense. Very limited funds. Gem. Hx
댓글 달기
답변 12개
가장 유용한 답변
Probably the display cable got dislodged. Make sure that it is tightly in its socket and see if that causes a change.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
all the cables seem to be connected. Can you locate the display cable and tell me if it is dislodged or not? I have 0 knowledge about hardware and I do not know which cable is which..
Make sure that the orange ribbon cable at top and black ribbon cable at bottom are in their slots. If necessary, carefully detach and reattach the cables.
댓글 달기
Open the tablet, disconnect the video ribbon cable and clean the contacts thoroughly with a stiff brush, being careful not to damage the ribbon cable. Reconnect the video cable, again being very careful not to damage it and being sure it properly seated under the hinged clip. Put your tablet back together and try it now. More often than not this fixes the problem of colored stripes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
==Working but color is all off==
I have had my Samsung galaxy 10.1 for 1.5 years. It still works OK but the color is all off making it look something like a colored negative. No knowledge of miss use or dropping. If I hold each side and apply slightest torque the color returns to normal.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the exact same issue as Zeid and Stan!
I have a galaxy tab 10.1 and it slipped from a chair onto carpeted floor, barely a foot.
I've opened it up, pressed all connections in and the display is working again but the colours are all off.
Is there a fix for this?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a problem with my RCA tablet and the problem is probably that your lcd is out of its socket or your digitizer is no properly connected
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I can't believe the answers I'm reading. You can knock the cable loose by dropping it but you can't change the settings by doing that. It's the LCD that goes bad replacing mine for the second time now after dropping it it's not a big deal there's videos on YouTube
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
But its the cable for some of us. Just fixed it, and it WAS loose.
댓글 달기
My samsung galaxy A 8 fell down but screen didnot broken but full coloured any solution plzzzz
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How to remove vertical colored lines
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My Samsung galaxy tab a 10.1 or 8inch is still got alarms going and my music still plays when I press play through my earphones but I can't see the screen at all it's just vertical coloured lines help me please asap
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Sounds like you cracked the digitizer
댓글 달기
I've got a problem I've got the same tablet but it looks like this when on still works fine but is disfigured help?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have an issue. I tried flashing my Samsung Tab A 10.0 SM-T580 and forgot to wipe it clean. Now I have colored lines and cant boot into boot mode. It goes into downloaders mode but that's it. Please help?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
we i got come up with ramdon lines on my tabelt
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zied 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 58
30일 전: 192
전체 시간: 54,640
