My first guess would be a clogged drain hose.
Belt, Water Pump
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
댓글 5개
My model # is 110.27102310. Do these solutions apply to this model?
Cole 의
If I continue to use the washing machine when I have this wet clothes problem, will I be doing further damage to the machine? It is in a very tight location, so having it serviced will require removing a bookshelf and the dryer from the area before the washer can be examined.
Hildagarde Sanders 의
@hksanders no you will not but you are not doing yourself or the dryer a favor. the wetter the clothing the tougher it is on the dryer. Eventually you will have to get it fixed anyway....
oldturkey03 의
The loud noise could be motor striking the frame due to damaged or worn shocks. This will cause tub to sit to low in some models and the heavier the load the worst.( Worst case scenario the transmissionnis bad. Sorry.) Avoid washing rugs, comforters, load evenly, and avoid overloading . Use proper settings as well to prolong life of your machine.
Ted 의
Rugs and comforters , blankets, murder washing machines ? Is the rug more important or your washing machine ? Unless you have a model designed to allow that. Then follow instructions to the t.
Ted 의
