주요 콘텐츠로 건너뛰기
The first 8 inch Android tablet by Samsung.
50 질문 전체 보기
Indicator says charge low when it is not
After short use of Tab, indicator goes down very quickly and tells me to charge, when I know it shouldn't need it. If I switch off and back on indicator goes back up to a more believable level. I can carry on using and then same thing happens again. I always wait until battery very low before charging fully.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Most likely you are using the charger is not original or one of the amps not suitable for Galaxy Tab.
Or that the problem is a bug, then it should update software or restore the factory default values​​.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks.Charger is original which came with the tablet. However I have run battery down until would barely switch on and recharged overnight. Not had same problem yet. Tablet still under warranty so will return if happens again.
댓글 달기
귀하의 답변을 추가하세요
Elaine McLocklin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 487
