LCD digitizer assembly doesnt work after replacement (green lines)?
I saw your video for replacing the LCD-digitizer of my nexus 4 phone, and followed the steps carefully. After I placed the battery, I checked to see if the phone turns ON and the display is working before I complete the last step of putting the back coverplate. I successfully switched it ON, saw a perfectly working screen, and browsed through my apps. To complete the assembly, I put the back cover by gently pressing the frame along the edges, but suddenly I saw some yellow green lines in the middle of the screen. I switched it off and again switched in ON, but now the entire screen had light with no display.
To fix this, I tried again checking all connections but no luck. What could be the reason for the sudden loss of display when it worked perfectly fine moments ago? Is there a possibility that I damaged the LCD while putting the back cover on the phone?
I am also not sure about one of the ribbon connectors of the digitizer. There are 2 big ones which are prominent and has ports to connect. However, there is a little third one which also has to come through the gap but doesn’t connect anywhere. Has anyone also experienced this while replacing the screen? Any help will be appreciated.
좋은 질문입니까?
