주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
No service after battery change
Hi,
The battery of my iphone 5 died once, I changed it without issue.
It has died once again and I ordered a new battery... I checked the SKU nr and it is exactly the same model as the one which was working.
After change it shows "No service" and doesnt ask to unlock the SIM.
I decided to put back the old battery which was nearly dead... got the service back...
One friend had an original battery to borrow me. I made the test and no service again with this original battery.
I tried again the new battery, no service.
I only have network connectivity when I plug the nearly dead battery.
I've connected to Wifi to be sure to get the correct date and time.
I've doubled checked every transistors on the main board, nothing is damaged.
The 3g antenna is clean and correctly plugged....
I don't really know what to do now, any advice ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Well this is a weird one I have never heard of this happening to a iPhone before maybe someone will no the answer
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I finally found the issue.
My memory was full, and the iphone was unable to record the change of battery.
When I cleaned up the memory, the new battery was well recognised and network came back :)
댓글 달기
Fixed mine, just switched on airplane mode and switched it back on, and almost instantly it changed from searching , to my network provider!
hope this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Check date/time to be correct. Set auttomatically Date/time after you connect your phone to wifi if not you have to do it manually.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vincent T 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,540
