주요 콘텐츠로 건너뛰기
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 질문 전체 보기
putting my antenna back into my xperia z
I Took my phone apart and replaced the screen. I can not figure out if the antenna was mounted or loosely fit and attached on both ends. im looking for some form of visual to see how it goes into place. I have googled and youtube my issue. Thankyou
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
One part of the antenna fits on the upper motherboard, on the right side.
The other end is on another motherboard part which is located inside of the bottom "unit" where the vibrator/external speaker is located. You have to bend back the clasp (lightly, don't break it) and remove the motherboard piece to reconnect it easily. It is possible to reconnect it with a fine pair of tweasers, however, I find it easier to remove the piece, connect the antenna and put it back in.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Derek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,955
