주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
booting from usb external drive
Trying to fix my old PowerBook G4. I found my internal hard drive is dead.
I'm trying to reinstall the Mac OS-X but doesn't find any drives.
I attached an external USB drive (to try to install the software there) but doesn't find it. When I open disk repair, the external drive is there (the internal drive doesn't show)...
Any suggestions? Can I install the operating system in the external USB and boot from there?
Thanks!
David
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Can you give us the OS-X version you are trying to install.
댓글 달기
답변 4개
가장 유용한 답변
Sadly you'll need a FireWire HD which has the older OS's this system uses, either OS-9 or OS-X 10.5.8.
Your other option is to boot off of the grey OS installer disks that came with the system or a retail copy of either of the OS's I've listed here.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
If your internal drive is dead it likely needs replacing. Have you done that yet?
Sadly, you can't boot up the older PowerPC based systems (G series) under a USB drive, you need to use a FireWire connected drive and the drive needs to have a bootable OS on it for your system.
Depending on the OS version you are working with here you may need an older version or use a boot disk that was created on a G series system as the earlier versions of OS-X had two installs one for PowerPC based systems and the other for Intel based systems.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Google told me, if any, it can only boot via a firewire harddrive, because it is a notebook before intel or sth like that. Just google it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Just put your new disk into the g4 and make a normal install it from your macosx dvd...
Pd.- if you cant give us more specific details we cant give you more specific solutions
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
david 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 40
전체 시간: 1,862
