주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Why is the screen black, but the phone is still working?
The other day, I dropped my phone, I thought it was fine, but when I tried to turn it on, nothing happened. Now I know that my phone is on and working, because I can it vibrates when I switch the mute button, but the screen is completely black. I know that I should try restarting it, but the 'home' button is broken. Is there any other way to restart it?
Btw, I haven't ever broken it before, or had any repairs.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Hi Nicole,
It sounds like your LCD has either been broken of the cable has become loose.
I would try to re connect the cable and if that doesn't work I would simply replace the LCD!
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Before trying the steps Donley mention first try a hard reset - to do this hold both the power button and the home button (the phone will switch off) keep holding until apple logo appears on the screen.
If the ape logo does not come on the screen then follow donley suggestion.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nicole 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 157
