주요 콘텐츠로 건너뛰기
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 질문 전체 보기
Trying to repair power button flex cable
This is my first attempt at repairing an iPad 2. The problem was a bad LCD screen. Everything was pink.
I removed the digitizer, and shattered it in the process. No problem, purchased a replacement. I also severed the power, volume, and mute ribbon cable. No problem, purchased another one. However, it seems I am missing a board? I am confused because I never took any boards out....
The bottom end of the ribbon cable appears to need to be connected to something, and the top part, just below the camera appears to have a cable that needs to go into it. I have attached pictures for better reference.
Here is the replacement cable that was ordered:
http://imgur.com/CaWaAcc
http://imgur.com/DJ0mdtc
Here is an overview of the inside (should there be a board just below (above in the pic) the Li-ion symbol?):
http://imgur.com/04RTj0I
There is a pot here for a cable end, but I do not see that end on this cable?
http://imgur.com/reL4UCV
Again, it appears something is missing..
http://imgur.com/vcTwwB8
From anther angle:
http://imgur.com/JoJQYAP
Any help would be extremely appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It appears your ipad is a cdma version you have a power cable for a gsm version
here is the cable you need
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
David Walter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 165
