주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
AMD HD 6770M upgrade is posible?
i'm triying to figure out if is possible to upgrade my current graphic card (AMD HD Radeon 6770M, 512 MB) replacing it by a better one. My iMac dates from mid 2011 with 27 inches screen. If is posible what card could be a good replacement?
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
Try a search for this part:
27" iMac (Mid 2011) AMD Radeon HD 6970M 2GB Video Card
Item #: 661-5969 1009267
Replacement, 27" iMac (Mid 2011) AMD Radeon HD 6970M 2GB Video Card
http://www.welovemacs.com/6615969.html
See @danj answer here:
How to replace the video card?
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Sorry, your system does not have a replaceable graphics card.
해당 답변은 도움이 되었습니까?
점수 1
댓글 8개:
Are you pretty sure? =(
The last one I opened up had a soldered MXM board.
Wait... they SOLDER the MXM card DIRECTLY TO THE BOARD?
I was surprised too! It was a system being returned from a field office in Asia. Instead of the pin header you'ed expect it was soldered pins!
The thing has a MODULAR MXM slot on the board there and populated, yet they SOLDERED the card to the board....
댓글 3개 더보기
댓글 달기
Somebody has done it: https://forums.macrumors.com/threads/201...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
would an external gpu work? There is nothing wrong with mine, other than I cannot play Blizzard games now :/ thanks to them upgrading their coding to Metal 2
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I don't think it would. High Sierra has introduced eGPU support as long as it connected through Thunderbolt 3 port. iMac mid 2011 doesn't even has a USB 3 port...
댓글 달기
The 27-inch (Mid-2011) does not have a soldered GPU board. It’s attached to the logic board but on the back side. To remove, you loosen the logic board, detach the GPU cooling heatsink from the bracket and remove two screws holding the GPU to the logic board bracket. It slides right out of the board socket.
I figured all that out and tried to replace my shaky board with what should be a working HD6770M and all I get is a black screen. Ugh. Old shaky board goes back in and I’m back where I started - pixelated primary and secondary screens. One of the heatsink screws was flopping around in there right up against the GPU terminals so maybe I just got a bad replacement board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
frankgumeta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 17
전체 시간: 17,222
