주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Can I install this iPhone 5s home button on my iPhone 5?
Hi guys,
I was looking online and why not, I thought having an iPhone 5s style home button for my iPhone 5 would be cool. So I came across into this:
White Home Button Key Cap Replacement With Rubber Gasket Pad For iPhone 5S
So, if any of you guys can help me out and let me know if it will work on my iPhone 5 it would be greatly appreciated!
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
가장 유용한 답변
You can buy a 5er homebutteon looks like 5s it works for sure. I will have not the fingerprint
feature but looks like 5s.
Have fun.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you, I know that it wont have fingerprint feature but it will look like a 5s.
But I am a little skeptical because the description says "for iPhone 5s".
in fact, This one looks way better than the others 5s home button look a likes that are complete aluminum. (I've been researching for a while) and even though it is not that expensive, I don't want to get my hopes up and go into the hassle of opening up the device for nothing.
Thanks.
Check this out here you can find what you are searching for.
Have fun.
http://www.ebay.com/sch/i.html?_from=R40...
댓글 달기
can I Install the iPhone 5s Homebutton on iPhone 5C too ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
generally they make custom home button for all sorts of iphone.... they even make this button for iphone 4 ... just check that it will work in iphone 5c before you buy
댓글 달기
it doesn't work because you would have to add different software to the phone. I have a 5c and i just bought a fake touch id home button. I hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
software and hardware as well. The iphone 5 and 5c have a really simple way of connecting to the home button, with two electrical; contacts. when you push the button it completes a circuit. I have "hit" the home button many times by bridging the gap between the contacts many times with a metal object in order to go home while testing a disassembled phone. And anyway the iphone 5s has a complex data cable for its home button.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alec 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,064
