주요 콘텐츠로 건너뛰기
모델 A1225 / Early 2009 / 2.66, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
164 질문 전체 보기
Computer shuts off after a few minutes of use
Hi,
My iMac (early 2009, 24") started shutting down after a few minutes of use. It's not a clean shut down. It's an instant cut-off of power.
Using Hardware Monitor, everything looks normal except with the Northbridge...
- The voltage sensor always shows 0 volts.
- The current shows 0 as well.
I've tried resetting NVRAM and SMC, but that hasn't helped.
Does anybody have any advise before I replace the system board?
Thanks,
Jay
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
if you haven't already i would try cleaning the dust out, make sure the fan is still spinning, it sounds like a possible overheating issue
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Michael.
Overheating was the first thing I thought of. I tried all you suggested.
I also tried using smcFanControl to increase the fan speeds. I replaced the thermal compound on the Northbridge as it was running a little hot (about 75 degrees C at idle). It now runs about 5 - 10 degrees cooler. Everything else seems to be running cool.
So far, nothing has helped.
댓글 달기
Best to take the frame off and take a look at the diagnostic lights when it goes down. That will tell us where to look.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Mayer. I did that too. It goes directly from 4 lights to 2. Unfortunately that doesn't help.
댓글 달기
귀하의 답변을 추가하세요
Jay Thomas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 294
