How do I fix the broken tip of a microsoft surface pen?
the tip of the surface pen from the microsoft surface pro tablet is accidentally detached from it do you know how to put all the parts back again? Nothing is broken just that the parts came off.I tried searching for many solutions but none you are the only hope left pls help thx
좋은 질문 입니까?
댓글 4개
What if the tip breaks off (dropped pen) and the rest of the tip is inside - how do I remove the rest of the tip in order to insert another top?
karlhermannjhu85 의
I got the same question!
Rudi Erlemann 의
Can you pick it out with a needle/pin? (fun tip - those dressing/dress pins with a little ball on one end can give you buckets of extra control here, plus dressing pins tend to be the thinnest things around, needles vary a lot more in thickness/sharpness)
imoddedit 의
What if the black part of the tip falls off and now I can't write with it?
Jaren 의
