주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for laptops manufactured by ASUS.
20 질문 전체 보기
Why my pc could not start open the system
How to attempt to repair my pc w/out using cd rom
windows could not start because the following files is missing or corrupt. /windows/system32/config/system.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 3개
선택된 해법
hi balboanelson,
could you remove the other topic you started? - i edited the text of the other one into this question - it's the same problem and there are possible ways to fix it.
first of all - here is the knowledge base article from microsoft about the error message - the problem is - without an optical drive or a working xp setup on an usb stick - you're stuck here.
if the eee pc is still in it's original configuration - it could recover it's operationg system with one keystroke - but normally that means that all your data will be gone after that.
after you powered on the eee, hit F9 (around a second after the bios splash screen) and the eee then loads a menu:
Normal Boot
Perform Disk Scan
Restore Factory Settings
in your case you should use the last entry
이 답변이 도움이 되었나요?
점수 4
댓글 달기
You would have to have a recovery disc to fix this issue. I don't know of any way to do it without.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
+ Agreed Ralph
댓글 달기
there's this bunch of sites that teach you to install the XP recovery CD to USB flash drive, i tried doing those tricks but still not succesfull all i got is boot somthin errors
let me know if you find any easy steps for recovery CD to USB boot
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
balboanelson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,983
