주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
AHT- 4SNS/1/ 4000000 :ic0r-10996
Hello guys!
my fan keeps working all the time on a really high level plus there is a kernel task failure which causes my mbp to work really slow. aht figured out a 4sns 1 4000000 icor 10996 troubleshooter. what is it exactly? there also is a problem with detecting my battery from time to time. doesnt load and recognize the battery regulary.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
If you've dropped or stacked something on the laptop the battery could be cracked. I had a MBA battery that would act very strange... Not showing up, then working fine. Not charging, then charging fine. I could not see the crack in the battery until I lifted it out of the case.
Apparently as I held the computer from one edge or end, or moved the computer the crack would open/close causing, then solving the battery problems above.
I believe the sensor is reporting a problem with the power (current) to the Optical drive. This could be related to the battery problem.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
malledive 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 431
