주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone stuck on low battery charging screen
Hi, yesterday I changed my iphone's battery and everything was fine, I charged it up to 100% and drained to make it's first cycle.. then, when it drained out, I left it turned off for about 2 hours, I connected to the charger and this screen appeared:
ok, seems normal, everything is fine... left it charging for about 2 hours and the screen was the same, I thought it was normal as the battery was new, so i left there for 1 more hour... then I went to see and it still on this screen, ok, I searched for help on everywhere and I couldn't find a fix for it.. so, I've already tried to force reboot a lot of times and restored it 5 times, and still at the same screen, after this I thought "ok, I will leave it charging over the night, maybe this is the problem" I left it charging for about 8 hours and still at the same screen, what can I do??? I've changed the battery recently, the battery is NEW
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 5개
선택된 답변
More than likely a faulty battery
Can you try old battery again ?
If it's threw out then you need another battery from a different vendor
If the same thing happens again after another battery then it's possible you have knock off a componant on the motherboard when removing battery
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I figured out what was happening.. I have to change the new battery to a newer one, the old one still working, the problem in the new battery is: it won't charge after the first complete drain... will contact the vendor to change it, btw, thx for helping me
댓글 달기
See more
http://www.any-data-recovery.com/tips/ip...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have the same problem do i have to get a new battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You have to notice that the improper connection of battery on battery connector causes that most of the issues,
That the following reason might be check it step by step.
Charging port might be dirty.
battery connector loose connect.
The BSI point of battery connector and near parts broke down ,open or remove unknowingly while falldown or battery replace.
The must know about the Bsi point and it`s function check this the process.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
throw it off a skyscraper then pick it up and dip it into fuel ,then lit it up. after burning for an hour dip it into water then take it out and dry it . Now charge it. THANK ME LATER
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Oliver 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 133
전체 시간: 52,068
