주요 콘텐츠로 건너뛰기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
Mother board getting hot upon reassembly.
I disassembled my PS4 controller to paint it. Reassembled correctly from every video ive watch but when I connect the battery the spot to the left of it gets hot and the controller wont cut on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 4개
did you check if you got any paint etc. on the logic board? Heat on a circuit board is usually caused by shorted out components. Do not use your joystick until you find the cause for the overheating, this may cause more damage.
The mother baord was no where near the painting.
Found the problem, the touch pad connection wasn't good. Blew it out and wiped it off and it's ok now.
My TouchPad works fine but the section of the board where the buttons go still gets pretty hot, not sure what to do
댓글 달기
답변 13개
가장 유용한 답변
I had the same issue and for me it was an issue with the touch pad ribbon cable being disconnected. The one in the actual touch pad not the connection to the motherboard.
So open up the touch pad and check if the connection in there sits correctly.
이 답변이 도움이 되었나요?
점수 7
댓글 1개:
For me it was exactly the same. At first I missunderstood what is meant with the ribbon cable at the touchpad. I always looked at the ribbon cable that comes from the touchpad and goes into the logic board. If you don't really know what to do, look at this video I found. It helped for me: https://youtu.be/MUzqnf7nqsE
댓글 달기
I had the same problem when reassembling my dualshock 4...
The touchpad ribbon cable turned out to be the source of the problem...
Solved by detaching and re attaching...
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
That didn't work for me I tried it twice
it dint work for me at first but then i tried moving the other end of the touchpad cable and bam it started working.
댓글 달기
I've got the same problem, and upon closer inspection, I've noticed that the power management chip (BD9200) gets extremely hot, way past what should be normal, I'd say easily above 100°c within seconds of plugging it in.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have the same problem with my controller. I replaced the thumbsticks with the ones from the Xbox One, and after I plugged the battery in, the motherboard was getting hot even when the controller was turned off. I think something has been damaged unfortunately.
MorbidStix offers replacement parts for Dualshock 4 controllers, I think buying a new motherboard is your best chance.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Read my comment above. Make sure the touch pad ribbon cable is wiped and blow out where you plug it in. I just wiped it off with my finger and opened the ribbon spot then blew it out and put the ribbon in there and closed it. Works fine now.
Worked like a charm, thanks bro !!!!!
I wiped the ribbon for the the touch pad and assembled it several times but the motherboard still gets extremely hot when the battery gets connected.
Please help!!!!
Cool, thanks. I'll try it. However my controller does work, but the battery drains very fast and I think it has something to do with the circuitboard getting hot. Could please give an update if you experience the same problem?
Mine didn't work when I had the problem but works fine from what ive noticed so far.
댓글 달기
I've had the same problem but blowing the touch pad doesn't fix it it just has no signs of working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i have the same problem! .. what i can do now ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Does any one know how to take out the circuit board?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My problem is itry to cut 2 engine which use for vibration after that my controller not working and mother board have some heat
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The mother bored in my ps4 controller is over heating every time I put the battery in ? Help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thank you so much!! After hours searching the net for lights not turning on or not charging, I gave up thinking the controller broke. Luckly I gave one last try and searched for getting hot, which it was a bit, and found this!
I had disassembled the dualshock 4 to fix the triangle button which was getting stuck. After that the controller simply wouldn't work. With your help I just cleaned the flat cables a bit and it came right back to life :D
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
How do you clean the cables?
I just used a clean cloth like those used to clean up TVs or glasses. However, I put it to charge and some days afterwards (I don't play much) it was not working again. I didn't bother opening it again as I have other controllers but I'll do it if I need this one.
Help me it won't work
댓글 달기
I have the same issue. After reassembling my ps4 controller, I noticed that once I pressed the touchpad in my controller discounted. It would not turn back on, or even light up, so I decided to press the reset button. This worked and my controller turned back on, but after pressing the touchpad once again my controller disconnected. I opened my controller and pulled all of the ribbons out and put them back in again. This did not work and my controller refuses to even light up now, even after pressing reset. Does anyone have any idea how to fix this, or know what has happened? All help is greatly appreciated :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my ps4 dualshock won’t charge after heating the board with hot air gun for replacing the analog button with the new ones. The analog button work fine now but the controller itself only works when I plug it with usb.
Does anyone know how to fix it?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Sounds like you over hearted a capacitor or a circuit. Next time only use a solder iron just for this purpose. A heat gun gets much too hot for small circuitry like a DS4 controller. The smaller the circuitry, the less heat that is required to desolder and ultimately damage tiny components.
댓글 달기
Dual shock 4 not on contact battery heat Mather board
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SU44K8 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 127
전체 시간: 14,091
