주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
20 질문 전체 보기
MagSafe Sticker / adhesive
Hi,
since my Macbook is fully disassembled I decided to clean the ports and hubs etc.
They are REALLY dirty.
I started with the MagSafe . So I disconnected the MagSafe Board from the logic board and started to rub with a Q-tip and 99% Isopropanol.
But immediately the sticker came off.
Do you know where I can find a replacement or whatever
and Q-tips are a bit too big for the USB Hub etc . Does anyone know a smaller alternative?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Quick follow up on this question: Is there any danger using a mac without this plastic part?
댓글 달기
답변 1개
AFAIK there is no source for small parts like that. (You could try to pick up a damaged unit from e-bay but you'd still be in the same place... removing and reapplying the insulator) If you can't put some spray/brush adhesive on it you could try some double sticky tape.
You could also custom cut an INSULATOR out of electricians tape.
If this answer is acceptable please remember to return and mark it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Buco Escobar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 474
