주요 콘텐츠로 건너뛰기
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
1209 질문 전체 보기
White smoke coming out of Troy-Bilt TB110 Lawn Mower
So I started mowing the lawn and it seemed a little rough mowing for about 10 minutes in and it shut off. I looked at the blades to see if there was any clump, not much and seemed rough still after I turned it back om and it seemed like the oil was low so I put more in but I wonder if I overfilled it. White smoke is coming out now, if I leave it on long enough will it go away?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
You'r burning oil. When you looked at the blades did you turn the machine on its side? If so clean the air filter. You can also refer to the user manual and drain the oil and refill it to the correct amount.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
mayer is correct, you can clean air filter and yes it will go away.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How do I clean the air filter? It clearly has dirty oil in it (the engine has about 4 hours on it).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 32
30일 전: 128
전체 시간: 8,196
