์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
๋ชจ๋ธ A1297 / 2.66, 2.8, 2.93, ๋˜๋Š” 3.06 GHz Core 2 Duo ํ”„๋กœ์„ธ์„œ
laptop keep restarting when using
when working and using my laptop it restart by itself
and loose my work
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ -1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
All modern processors has a safety feature that shuts down the computer once the processor reaches a certain temperature, to ensure that the processor is not damaged.
Typically the processor overheats if the air intake vents are blocked - either if you are using the computer on a pillow, blanket etc. which restricts the air flow into the fans or because the fans are blocked by dust.
If you are up for it, I would suggest that you clean the fan. The procedure is not that complicated and can be done by almost anyone :) As an example, you could follow this tutorial: https://www.youtube.com/watch?v=nv8rZYut...
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
nazih hudhud ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 0
์ง€๋‚œ 30์ผ: 1
์ „์ฒด ์‹œ๊ฐ„: 178
