주요 콘텐츠로 건너뛰기
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
My LG G2 LCD screen is coming off after replacing it?
Hi,
I have been fixing my LG G2's LCD+Digitizer and I think the stickytape didnt do a good job, is there a way ( maybe glue or something?) to make the screen stick better to the ducktape without re-opening the whole phone..? I had a hard time doing that, lol.
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개:
I have the exact same problem with my G2. Repairer said the tape is spongy and there's nothing they can do about it. But surely there must a fix for it? ? Please help!!
댓글 달기
답변 1개
I had the same problem with mine. Is it that bottom right corner? You're going to have to disassemble the phone in order to get tape under there to stick properly. I would not attempt to adhere the phone without fully removing the screen.
Your repairer should do this for you as this is a failure of their repair. How long has it been since you got it replaced? Was there no warranty on the replacement?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Well, I did the repair myself with the sticky tape. Yes it is the right and left bottom. I can see the white LED lights when its dark. The top part is fine, there was enough space to attach stickytape on it.
Would u recommend using superglue with a narrow end to glue it in both corners? There is a pretty good space to do it, if i could find glue that goes trough a small needle to be verry carefull.
댓글 달기
답변을 추가하세요
Mike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 3,120
