주요 콘텐츠로 건너뛰기
Power Mac G5 Late 2005는 10월에 소개되었으며 다음 해 8월에 단종되었습니다. 2.0 GHz 듀얼 코어 프로세서, 2.3 GHz 듀얼 코어 모델 번호 A1177, 그리고 2.5 GHz의 듀얼 코어 듀얼 프로세서 (쿼드 코어)의 세 가지 구성 옵션이 있습니다.
26 질문 전체 보기
WD40EURX - how to make them running as internal HDD
Hi
I just bought two WD40EURX (4TB) SATA to replace internal discs in PowerMac G5 7.2. I had a lot of problem to make them formatted and partitioned into two partitions 2x1.8TB using MacBook Air and 10.9.4 in external disk dock. I have formatted them using Apple partition system. Moved them to the PowerMac and booted from DVD. Now I can see only one disk but I cannot use any of partition. When I tried to reformat disk - system hand up. Any idea? Do I need to put jumper to 5-6 pins to lower speed to 1.5?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Yes you will need to slow down the drive to SATA I (1,5 Gb/s) as your systems SATA interface is only SATA I.
You may encounter issues with these larger HD's depending on the OS-X you are using on this system. Review this Apple TN: Mac OS X: Mac OS Extended format (HFS Plus) volume and file limits.
But before you start this project are you sure you want to make this investment on such an old system? Remember this system, OS and apps are not supported any longer. It also is very exposed to internet viruses and trojans if you are using it online.
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
Hi. I'm using on my PowerMac G5 MacOS 10.5.8. I just want to use this machine as iTunes Server and to have all iPhoto libraries available @ home network only. I have slowed down drives by connecting jumpers 5-6. I've done two partitions - each one is 1.8TB
Still does't work. I cannot install MACOSX on desired partition. Installation is causing FREEZ of the machine with death screen (after 10 minutes)
I don't think this drive can be jumpered to a slower speed. I've looked at what WD has and none in the series have a jumper and I can't find any docs that talk about a compatibility jumper either.
댓글 달기
귀하의 답변을 추가하세요
Jarek Zurawski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 205
