I phone 5 battery keeps dying out
i replaced the battery twice and it keeps dying or running out quickly
좋은 질문 입니까?
좋은 질문 입니까?
Hi Jose,
I assume your iPhone is out of warranty which is why (or because) you replaced the batteries to try and fix this issue. Otherwise I would take the iPhone to Apple for replacement under warranty.
I believe you COULD have a faulty charing-IC (or set of components). This is a very common failure in iPhone 5.
A good way to tell is to let your battery drain until the iPhone shuts off on its own. Then try to recharge it, making sure you are using a known good (better if original) cable and a known good charger.
- If it does not charge and restart (usually takes 5-15 minutes), it means the fault indeed lies with this charging-IC. The iPhone should not restart anymore until you have the culprit component replaced using the services of a professional repair shop or repair technician with micro-soldering skills. And I would not throw away the batteries you replaced, because I believe they are not at fault.
- If, however, your iPhone does restart after the battery had drained out completely, it could mean many things such as:
You could be using bad quality batteries (very common).
You could have excess battery drain due to software issues (back-up your iPhone, restore software using iTunes, re-install your bak-up. If you need detailed instructions let us know here).
I'd say it is better to start with the battery-drain-then-recharge-test to confirm or rule out the charging-IC possibility.
해당 답변은 도움이 되었습니까?
If all battery's are dying like that then it's the U2 chip that's the problem on the motherboard
해당 답변은 도움이 되었습니까?
If the problem consist on the charging-IC, who will repair that? Apple doesn't want to deal with my phone because I already replace the Apple battery with a third party vendor. l
해당 답변은 도움이 되었습니까?
Magda, where are you located?
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 4,674
