주요 콘텐츠로 건너뛰기
Model A1318 / 32 or 64 GB capacity
299 질문 전체 보기
Why is my 3.5mm socket/jack loose/broken?
Plugged 3 pairs of earphones in. Sound isn't working properly. I have to move the earphone plug around to hear the music fully. No lint recovered from the socket/jack. Why is this happening? Is it fixable?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
at first - here is the teardown, as you can see in step 5, the socket is on the bottom right corner - there are 4 soldering points - one of those could be damaged, it's also possible that the ribbon cable is faulty - there are ways to fix this without a new part. but i would first check the part for any damages
it's also possible that there was a fluid damage - is the indicator inside the socket red ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have been told that wrapping 1/4” copper tape around the pin will slightly beef up the pin width, making the contact with the jack phones snug enough to solve the problem? Has anybody else tried this successfully?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 6,354
