주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1297 / 2.66, 2.8, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
Battery Temperature Sensor Error
I replaced my MacBook Pro Battery and after running ASD i got the following error:
[09/08/14 12:56:12] Temp (TB3T) - Battery temperature (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[12:56:12] ERROR -- 1 [Unable to read sensor] -- (-1.00) TEST FAILED
Can anybody help ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Only you know if you damaged any connectors or components on your logic board during the DIY repair.
Go over all your connectors/connections again... many times DIY find that what they "thought" or "believed" was a proper connection was not square or "snapped in".... sometimes ribbon cables were not unlocked or relocked... or the ribbon not fully inserted in the connector.
If this answer is acceptable please remember to return and mark it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Christos M 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 796
