주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
No picture on LCD but backlight works
I'm currently working on an iPad Mini Retina wifi and can't figure out why there's no picture on the LCD but the backlight works. It's clear as day that it's lit but nothing shows up. The device syncs to iTunes but I think it needs to be unlocked or something since it won't let me in.
I've tried multiple LCD's and the exact same thing. Not sure what else could be wrong. I'm assuming it could be a fuse or resistor on the motherboard but I don't know which one or where to search for it. I'm assuming it's next to the flex connectors on the motherboard. If so how in the world do I test those? They're like the size of lint!
Please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 5개
No clue anyone?
Did you ever find a solution to this? I am experiencing the same problem now.
I have this same problem. If I plug back in the old LCD it has a picture. But the new LCD only the backlight comes on, no picture.
has anyone had a solution for this?
댓글 달기
답변 2개
가장 유용한 답변
Tap around the back of the frame. Sometimes this causes it to come back on, for whatever reason
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
maybe you did not connect the ribbon cable in all the way sometimes that the culprit . sometimes we get in a hurry putting thing back together. or could bent it jus a little.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
npham54 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 1,418
