주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 not restoring!
Hi,
I have an Iphone 5 (A1429) that randomly went into dfu mode... I wasn't able to get out of DFU nor do a restore (itunes would hang on "waiting for device").
After charging the battery for a night (it gots charge now, checked it with voltmeter) i got it to a stage where it is dispaying the itunes logo with usb cable (recovery mode) but i can't get out of that either (tried holding home and power for 10 sec, restarts and goes back into the same recovery mode)
if i connect it to Itunes now, i get it to actually starting to restore but 10 seconds after the status bar displays on both my laptop and iphone, itunes stops with error 14. I already tried re-installing itunes, deleting old IPSW and tried other wifi/ computer. I'm desperate so pleas help, i'm willing to open up my IPhone and i'm in possession of a mac, windows and ubuntu PC.
here is the log i get (only error section):
[15:25:29.0492] Failure Description:
[15:25:29.0492] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 14
[15:25:29.0492] Depth:1 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 14 - Failed to handle data request message)
[15:25:29.0492] Depth:2 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 14 - Failed to handle image request)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
here is the full itunes llog...
http://pastebin.com/NMKaz53j
댓글 달기
답변 3개
선택된 답변
just fixed the problem by doing a restore on an apple macbook... it looks like itunes for windows is not supported as much as the one on itunes as 3 windows pc's gave me the same errror and the mac just restore without a problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Change battery and try again. .
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi,
thank you for answering. In the weekend i'll swap my battery with a battery from a working iphone 5 (once I find someone who will let me use their battery :p) and post the results here...
thanks!
also,
my battery is giving me 4.25 volts on outer connections of the battery, is this enough you think? (i charged it 2 full nights...)
thanks!
댓글 달기
Try entering DFU mode to solve iPhone stuck in recovery mode:
Plug your device into your computer
Turn off the device by holding the Sleep/Wake or Power button and swiping it off
Hold the power button for 3 seconds
Begin holding the Home button without releasing the Sleep/Power button for 10 seconds
Release the power button and continue holding the home button until you get a popup from iTunes that your device is recognized as being in recovery mode.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lennert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 4,306
