주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
LED Back Light failure
three days ago, my screen started to flicker and the bottom of the screen began to dim with gray triangles appearing across the screen. I took this to mean that I was having problems with the LED back light power supply. After 5 minutes, the screen went totally blank. I can barely make out the what is on the screen so the system is still working. Since I bought a service agreement, I called Apple and they immediately sent me a box. I received an email today saying that it would cost almost $1,300 because there is an indicated patch that said that the unit had water damage. That was a surprise to me and additional research has indicated that this marker can turn pink due to moisture in the air. I researched iFixit to see if there is anything part to replace that would fix the backlight but all I seem to find is replacing the display. Is this correct? Thanks for the support.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Yes moisture/humidity has been known to trigger the moisture indicators. You could ask for a reexamination/consideration if indeed there has never been liquid on the machine (there should be apparent difference between a "moisture" trip and a liquid trip... but that may make no difference to the fine legal print)... however if you do not ask for a review you won't be offered one.
Depending on what part of the backlight is bad (your display is LED backlit... the phosphers are on the display, not a separate tube as in early LCD modles) you may need a display, or, a controller. Both are involved repairs.
If Apple would spec what part(s) they intend to replace you might be able to DIY.
If this answer is acceptable please remember to return and mark it.
Replace a display compatible with the MacBook Pro 15" Unibody early 2011 to late 2011 A1286 model laptop. Includes the LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables. 이미지
제품
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
$149.99
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you MACHEAD, I will be calling them today or Monday to discuss the moisture trip. I believe that it will probably be the controller since I can see the faint screen image which leads me to believe that the power to the LEDS has failed. If things go wrong and I don't want to invest in a DIY repair, I will turn it into a desk unit and apply the repair money to a new IPAD when they come out in November.
A logical choice.
Live Long and Prosper!
댓글 달기
Apple announced an repair program 2/20/15. Go here to check if you qualify: https://www.apple.com/support/macbookpro...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
danatmurphylake 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 379
